Wideband reading indcorrectly....
Ok, So I finished wiring up the LC-1 wideband and dyno tune gauge. Its working but seems to think 7.x is 0 and somewhere around 22.x:1 is stoich. I talked with the guy at dyno tune and he said that they pre calibrate all there widebands before they send em out so you dont need to. Is there any way to zero it out? Its a pain to get to all the wires and sensor because of the placement. Its a C5 so everything is above the tunnel plate (37 bolts). Any help?
You should have a data cable (serial) to connect to the LC-1 controller. Install this cable, if not allready, and you can then use your laptop to re-calibrate the LC-1 outputs. You may also need to perform the free air calibration again.
I don't have the link to Innovative's web site, but all the latest documentation can be downloaded from their web site
