What to tune with a high stall converter? po757 code
just had the converter installed a few days ago and i got the po757 code. From what i read this is due to the high stall as well as a lighter converter.. I get shudder at low rpm locked condition and heard that the pwm/tcc apply needs to be adjusted.. I also heard something about the missfire codes need to be changed. Can someone tell me all the typical things that need to be changed when going with a higher stall. The computer doesnt seem to like it much(drives ok except for the lock up shudder when applying more throttle under cruise conditions.)
