Going through HP Tuners 2.0
Old 10-19-2005, 12:57 PM
7 Second Club
Phil99vette's Avatar
Default Going through HP Tuners 2.0
Man, I love the new features they added. I am interested in seeing if we can use a histogram to dial in the RAF table alittle easier. I also like it that you can use a histogram to log the secondary VE table vs the primary so it should make VE tuning slightly faster. Overall the new additions are simply amazing. Did I read some where that instead of logging 24 parameters you can log 48?
Phil
Old 10-19-2005, 01:03 PM
horist's Avatar
yup you can log up to 48 bytes... but I believe once you go past 24 the refresh rate (frames per second) goes down
Old 10-19-2005, 01:10 PM
LS1 Tech Administrator
Patrick G's Avatar
Does the histogram now take an average reading at each cell? I have HP Tuners V 1.6 and it only showed the last value to hit each cell. Made nailing the VEs very hit and miss.
Knowing how many times you've hit each cell and getting the average value of it is one of my favorite features of EFI Live.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 10-19-2005, 01:23 PM
7 Second Club
yeah V1.7 had the averaging feature. Being able to use a histogram on all of the tables, RAF, MAF, VE Ect... is gonna make this software kick ***.
Phil
Old 10-19-2005, 01:29 PM
LS1TECH Sponsor
Magnus's Avatar
Patrick G, right click the histogram.. Also read the 1.x help files.. We've had all sorts of histo value support since we released the 1.x scanner..
There are a LOT of features in both software platforms, 1.x and 2.x.. be sure to check the help files.. as we document as many features as we can.
Also, for the RAF and such, we included default histograms in there.. Just click the open file icon on the histogram window to see what is included.
Also, check the help files in the acknowledgments section.. You can submit your own histograms, writeups, etc. etc..
hope this helps
Old 10-19-2005, 01:43 PM
Patrick G's Avatar
Thanks for the help! I'll check it out.
Old 10-19-2005, 01:48 PM
soundengineer's Avatar
Phil
yes you can do RAF in 2.0
www.audiohelix.com/file
a list of all my histograms and some custom PID's listed in the description if it needs it
and a list of bytes max vs frame rates
Code:
                     24 Byte Max	48 Byte Max
1-6 Bytes	20 frames/sec	40 frames/sec
7-12 Bytes	10 frames/sec	20 frames/sec
13-24 Bytes	5 frames/sec	10 frames/sec
25-48 Bytes	n/a	            5 frames/sec
	            56 Byte Max
1-7 Bytes	40 frames/sec
8-14 Bytes	20 frames/sec
15-28 Bytes	10 frames/sec
29-56 Bytes	5 frames/sec
Old 10-19-2005, 02:00 PM
LS1TECH Sponsor
foff667's Avatar
Phil
I personally still wouldnt log a secondary ve...i would just go ahead & adjust the primary & do your smoothing or what have you...then just copy/paste your secondary...making an excel file will help speed along that process
Old 10-19-2005, 02:03 PM
7 Second Club
Why wouldn't you log the secondary?
Phil
Old 10-19-2005, 02:06 PM
Phil
because then you have to smooth 2 tables...
in my link above there is an excel spreadsheet section..
has a primary to secondary ve table..quick and easy as a copy and paste
do all your work on the primary...only have to do the work once....
copy paste..copy paste.done
Old 10-19-2005, 02:09 PM
7 Second Club
When do you change the "Byte Max"
Old 10-19-2005, 02:21 PM
its automatic per vehicle...
you can add or subtract PID's to get the desired frame rates...
I can tell my wideband to report as fast as possible or to only report what it averaged every 10ms(or 1 frame in HPT at 24bytes max) or I can tell my wideband to report the average over 5ms...and I log only enough PID's to get me in teh 7-12 byte range or 1 frame every 5ms
Old 10-19-2005, 04:14 PM
Originally Posted by Bink
HumpinSS - Nice sig. ......
bah humbug....
something similar coming soon from HPTuners
Old 10-19-2005, 04:57 PM
Originally Posted by Black02SS
Always has to be a hater.
well this is a thread regarding HPT 2.0....so I haev to point out stuff about HPT
and besides... I'm not a hater... I'm a rationalist and a realist..LOL
Old 10-19-2005, 05:07 PM
LOL
my previous post was informative...
and so you know...
cutsom PID for LTFT+STFT is
[SENS.114]+[SENS.116]
Old 10-20-2005, 07:01 AM
TRex's Avatar
Originally Posted by soundengineer
bah humbug....
That means it's a year away
