60# Injectors - High Flow Rails - Sale @ Speedinc.com
60# High Impedance Injectors - Set of 8
We have taken these injectors up to 850RWHP with our Turbo System and the stock PCM using HPTuner's 2/3 bar setup.
Normally $499.99 - On Sale until Oct 31st - $429.99 Click to buy
Have a newer GM or Ford vehicle that uses a new injector plug style?
No Problem!
Speed Inc offers a set of injector harnesses for a very competitive price. Now you can use those large 60# injectors in your GM truck or Ford Cobra.
Every day low price of $69.99! - Click to buy
Last, but not least our fuel rails are found on some of the fastest LS1 powered vehicles on the track and in the magazines. Our very own 2002 Z28 just ran a 8.95@153mph. This is from a car that weighs and drives like a normal street car! Available in Silver, Black, Red, and Blue colors.
Normally $179.99 - On Sale until Oct 31st - $129.99Click to buy
Installation Kit available @ $79.99 Click to buy
Coming soon - fittings to use with the installation kit to clip right onto the factory hard line!
....as always if you need any help give a call toll free at 866-LS1-SPEED or email us anytime at sales@ls1speed.com
Thanks!
Speed Inc Sales Team
No Problem!
Thanks!
Does your installation kit include all the fittings/braided line needed to connect to factory fuel supply/return hard lines?
When are the special clips coming out? I would want these with the rails if I order
2 weeks and we should be done with testing. The current kit will work, but it does not utilize the quick disconnect fittings. Worst case we will have this new adapter and a -6 to -8 adapter and it'd be plug and play.
I bought your fuel railsearlier this year and got them put in, but I have a question. The speedshop said that the directions were to disconnect the evap switch....was this to be reconnected once the install was completed.
Is there any other part that I need to have to remedy the smell?
Tom
