What else to do to improve cam only setup?
I've run out of things to do besides more weight reduction, so I was wanting ideas/suggestions as I may have left some things out. Here is a rundown on my setup:
Internal:
T-ReX cam (242/248 .608/.613 109 LSA)
Patriot Gold dual spring kit
Rollmaster double roller heat treated timing chain
Thunder Racing ported/blueprinted LS6 oil pump
Comp chromoly hardened pushrods (stock lenght)
Katech rodbolts
External:
ASP underdrive pulley
Intake:
Fast Toys ram air kit
K&N air filter
Texas Speed & Performance 85mm lid
SLP 85mm MAF
SLP bellow (new version)
Nick Williams 90mm throttle body
FAST 90mm intake (ported/cleaned up by me)
Exhaust:
Kooks stainless steel 1 3/4 headers 3" collectors
Dynomax bullets dumped after collectors
Cooling:
Meziere race electric water pump
Lowered fan settings
Fuel:
SVO #30 injectors
Racetronix fuel system
Ignition:
Holley 9mm wires
NGK TR-55
Tuning:
G-Force custom dyno tune
Drivetrain:
Trans-King TH350 w/reverse manual valvebody, transbrake, deep pan, JW Ultrabell bellhousing
TCI SFI flexplate
Protorque converter
Denny's Nitrous Ready driveshaft
Strange 12 bolt, spool, 4.56 gear, aluminum cover, 1/2 studs, narrowed 3" per side
Suspension/Chassis:
BMR upper & lower A-arms
BMR K-member
BMR relocation brackets
BMR TH350 trans. crossmember
Spohn chromoly adjustable panhard bar (poly/rod)
Spohn chromoly torque arm (poly)
Spohn chromoly sub-frame connectors
Billingsley offset lower control arms (rod/rod)
Hal 275 lb. front springs
Hal front R series single adjustable shocks
Hal rear single adjustable shocks
Wolfe anti-roll bar
Wolfe 6 point chromoly weld-in roll bar
Braking:
Billingsley ABS delete block
Strange/Billingsley manual master cylinder
Strange rear drag brakes
SLP line lock
Steering:
Madman manual rack
Tires:
26x4.5x15 Moroso DS-2
29.5x10.5x15 ET Drags
Wheels:
Bogart Floyd RT (front-15x3.5/rear-15x10 w/5" backspacing)
Internal:
Katech rodbolts
External:
Intake:
K&N air filter
SLP 85mm MAF
Exhaust:
Cooling:
Fuel:
SVO #30 injectors
Ignition:
Holley 9mm wires
NGK TR-55
Tuning:
Drivetrain:
TCI SFI flexplate
Protorque converter
Suspension/Chassis:
BMR K-member
Wolfe anti-roll bar
Braking:
SLP line lock
Steering:
Madman manual rack
Tires:
Wheels:
Originally Posted by Ben R
LOL, he's taken EVERYTHING out. It's the nicest looking gutted-car I've ever seen.
I'm thinking we upgrade to 1 7/8th headers and change up the cam a bit.
I too will be switching to 1 7/8 x 3 1/2 kooks.
All of the sound-deadening material is gone. We could do the lightweight carpet. Lexan is a bit much IMHO. He also is yet to add the Strange Race Brakes in the front.
do you have trouble hooking..that is a monster tire you got there...i would go to a smaller tire unless you cant make it down the 1/4 mile..and to me your 60 does not look that strong for a 2900 pound race weight...after the tires i would start with the verter and get that thing to 60..ive tried alot of name brand converters and there are differences in them...how much power does the car make...i think with a better verter and smaller tires it will pick up et and 60
SSU Moderator
new cam. maybe you can work a deal with thunder to try the new T-Rex with LSK lobes since you have taken the original pretty far. Or just get a new custom grind.
personnally, if you can scrounge the cash...just get some heads. Dart heads are cheap and flow well, and AFR 205's are dominating.
On the 10.54 pass he only went a 1.47 60' because the track-prep had gone away. The person just in front of us had wrecked and the track sat for about 45 minutes. He has been a 1.41 60' with only one suspension change, but I'm hoping I can get him to 1.37 60' with the same amount of power he's got now. We just need to go do more testing.
LS1Tech Co-Founder
01Z and Magnus went 10.29@128mph cam only so, I would maybe do the water pump, but I'd look for that 1.35 that that car should be able to cut as long as it has enough converter. Is it a 8" or 9" converter? I'd run an 8" converter for a setup like that, Magnus really showed that the 8" works great. 01Z switched from a 9" to 8" and picked up bigtime.
Sorry guys for the delay response. Ben has it right, but I'll cover it again.
Protorque converter, 8", stall speed around 5500.
VFN Sunoco style hood, no lexan glass
Airbags are out
I wouldn't say that everything is out as I still have the stock carpet, door panels, power locks, power windows, power mirros, t-tops, dash, and headliner.
The car only makes 400+ rwhp. I haven't had it on the dyno lately, but with the old setup, it was around 410 rwhp. I don't have trouble hooking, its just the track I race at doesn't prep that well for test n tune. I average mid 1.4s with the new setup, but when I pulled the 1.41, they had just laid down some rubber, VHT, and about 5 cars in front of me got the track a little warm. I think with better track prep, I could see consistent low 1.4s and when winter comes, 1.3s for sure.
I edited the list as I forgot to add Mezeire race electric water pump and Wolfe anti-roll bar.
Airbags are out
