5.3 Max overbore.......
Old 10-21-2005, 01:30 AM
FRANZ's Avatar
Default 5.3 Max overbore.......
Does anyone know what the max overbore for the 5.3 block is ????????
Old 10-21-2005, 10:58 AM
firefighter's Avatar
You can go up to 99mm from 96mm what that converte to in inches I'm too lazy to figure out but that is what the book by Will Hadzel says.
Old 10-21-2005, 06:31 PM
gearheads78's Avatar
96mm would be 3.78" and 99mm would be 3.90"
Old 10-21-2005, 10:49 PM
MAC4264's Avatar
I have seen these sonic test enough to go 4.00 no more (4.030). Wall thickness is about the same as the 6.0 when bored .060.
Old 10-21-2005, 10:57 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Firefighter is correct. 99 mm or 3.897" same as the 5.7 liter block. The 5.3 and 5.7 aluminum blocks are identical. GM used a thicker wall sleeve to reduce the bore diameter on the 5.3. I have machined several of these blocks for Darton MID sleeves.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 10-22-2005, 01:21 PM
Silver-Dollar's Avatar
how to build a hp ls1 says you can go to 99mm
Quick Reply: 5.3 Max overbore.......
