Car stalls at stops.
Full bolton car. 224/ 112lsa cam, 42lb injectors 99 LS1 LS6 intake. changes where followed the instructions on how to set your car up for speed density. no maf
The car stumbles, then fights to stay running then just shuts off.
and you've done the injector flow changes and idle VE changes? Any changes to the RAF table?
what are your IAC counts at warm idle?
If you just barely keep your foot on the gas, does that give it enough air to keep running?
Is the TB at its stock opening or have you adjusted the idle set screw?
The injectors have been scalled for the more flow. The ve changes where done 2 years ago when the cam was installed. the IAC counts are around 40 at warm idle, I will check those in little bit.. I have not changed anything to the RAF table. I dont even know what that does. I have not looking into that table. And yes the car will keep running if i give the car a little bit of gas. No i have not touched the idle screw and the TB has been ported and polished.
