Help with clutch!!!!
I need a clutch, but I dont know what to buy. (Yes I know I need a clutch.) I am looking at a spec stage 2, but what else do i need to buy? Do I need a flywheel?, or anything else in that matter? My car has 58,XXX miles on it. I want to keep cost as low as possable, so any advise will be helpful!
Mike
Mike
Mike
Mike
Unless you have alot of mods, why not take a look at the ZO6 clutch setup, holds well (at least for the mostly stock power levels)
Get the clutch and flywheel, ($350) and the upgraded hydraulics (slave $115, and master $143) you can skip the hydraulics if it's a 01+
That a low enough cost for ya
Prices are from the SDPC website (sponsor) -------------------->
I'd at the very least get your stock flywheel turned, but I'd recommend just getting a new flywheel. You're already in there, might as well do it right.
2k2 pretty much covered it... you don't need the upgraded hydraulics since you have an 01+, so the clutch, pressure plate, and flywheel should pretty much do it. Might wanna do the drill mod on your hydraulics though.
when u get your flywheel turned, you might have to shim it. i dont think mine was shimmed, plus i got the shitty hydraulics. so after 13k miles my spec stage 1 took a crap. im gettin the stage 3 and a new flywheel. that together is like 580.00. but i wont have to worry about shims now. plus im upgrading my crappy hydraulics in my 98' that gets a lil expenssive there tho. mcleod adjustable master-309.00 and mcleod slave 129.00 but ill never have to work on the clutch again. cause ill never push 680 hp, lol
Whether or not to get a new flywheel is going to depend alot on the condition of your current one, if you haven't beat the hell out of the car, you can likely get away with having your old one resurfaced, but just in case I'd budget for getting a new one, better safe than sorry.
I've had one that had a nice crack in it, that I found when I pulled the clutch off, then it was a mad scramble to find a replacement, so I could get it finished, this car wasn't beat on at all, but the flywheel was still unusable.
Besides, even if you don't use it this time, you'll probably need it for the next one
