Calvertcm2003
10-22-2005, 11:13 PM
put ls1 in 72 chevy truck with s&p wiring harness. getting fuel but no spark. What can cause a no spark problem
Jones'n
10-22-2005, 11:50 PM
Is the Crank position sensor plugged in? It is the sensor above the starter. That is the usual suspect.
hugger 6933
10-23-2005, 11:07 AM
Make sure that the wire that you have hooked to your switch is hot in all the positions it needs to be.Mine was hot with the key on but when I started to crank the engine over the fire would go out and it would not start.
Calvertcm2003
10-23-2005, 02:00 PM
thanks hugger you were right on the problem props to you thanks fired right up
