loud tic from engine!!
Old 10-23-2005, 07:12 PM
Mr_president's Avatar
Default loud tic from engine!!
ok well ive had a loud tic for quite some time! anyone have this problem my cam is not that big but i here they will make some noise however my friends doesnt tick close as mine does how do you no when your lifters are going out!!?? sure it not an exhaust leak
Old 10-23-2005, 08:33 PM
racecar's Avatar
You might consider taking off the valve covers and looking for a broken valve spring or a bad rocker.
Old 10-23-2005, 08:39 PM
ok cool thanks anyone else i used stock lifter with cam is that ok?!?
Old 10-23-2005, 10:07 PM
GREATWALLTA's Avatar
You said your cam is not that big. If the cam that you are talking about is the one in your sig I say its pretty damn big. Any way I have the same problem too, and almost everybody tells me its a bad lifter. My cam is a whimp compair to yours so I would say check your springs, rockers, and pushrods. If they are all okay then it will most likely to be the lifter going bad.
Old 10-23-2005, 10:09 PM
trix5032's Avatar
i have to ask are you still driving it with a bad lifter?
Old 10-23-2005, 10:16 PM
WS6kate01's Avatar
Deffinately check your spark plugs. My car had a nasty tic at idle. turned out to be a loose spark plug. It was louder under the car than in the engine compartment
Old 10-23-2005, 10:20 PM
trix5032's Avatar
a tic wouldnt get louder as he revs if it was a spark plug...
Old 10-23-2005, 10:25 PM
REDWS6ROCKET's Avatar
did you put in a ported oil pump. my car used to tick before my tsp ls6 pump. now no noise with heads and cam
Old 10-23-2005, 10:27 PM
WS6kate01's Avatar
well he never said it got louder when it revs, does it>?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
it is probably a bent pushrod or a broken spring (or 2).
I have a decent size cam, and it is just loud for valvetrain noises.
Old 10-23-2005, 10:36 PM
trix5032's Avatar
my bad i guess he just told me that through a PM, so now you know
Old 10-24-2005, 10:54 AM
WS6kate01's Avatar
oh ok, sorry thats ruled out then
Old 10-24-2005, 04:39 PM
382WS6's Avatar
I'd have to agree. I had the same tick and it ended up being two bent pushrods. Any chance you may have over-revved and floated the valves?
Old 10-24-2005, 04:44 PM
Yes Im affraid so. The car is the only car and its a DD so I will have to live with it until I can get some time off, and money to spent on bolts and gasket kit to pull the heads. I just hope it does'nt go before that.
Old 10-24-2005, 05:48 PM
ok my car does do it when it revs maybe i need an stock oil pump 2002 but the gaugh is at 40 most of the time ...i here it only when the cut out is closed
Old 10-24-2005, 08:22 PM
trix5032's Avatar
well just fyi but if it doesnt happen when your cutouts open then its not an internal engine problem.
if the cutout just over powers the sound then you may still have a problem but you should probably try to nail down just where the sound is coming from
Old 10-24-2005, 10:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, It is just drowning it out....
Old 10-25-2005, 04:07 AM
vettenuts's Avatar
Lot of lift on that cam, what springs are you running?
Old 10-25-2005, 04:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
hopefully he has doubles...
