how do you tell the diff between LS1 LS6 clutch?
Old 10-24-2005, 10:51 AM
SUTTERERMAN85's Avatar
Default how do you tell the diff between LS1 LS6 clutch?
i have a 99Z and the pressure plate looks the same as the LS6 replacement ones i have seen like on the net. do all LS1 and LS6 pressure plates look the same or what? i think my clutch is stock and it started sliping yesterday so its time. so my question is do i have the ls1 or ls6 because i al prob going to by the LS6 clutch but if thats already what i have, i might want to get something else. thanks in advance
Old 10-24-2005, 08:32 PM
anyone????
Old 10-25-2005, 07:18 PM
nobody knows anything??
Old 10-25-2005, 07:35 PM
Cephiros's Avatar
if your car is stock, its not a z06 clutch, if your not sure, i coudlnt help you
only 01/02 cars came with the ls6 clutch.
Old 10-25-2005, 07:43 PM
BrandonDrecksage's Avatar
is your car stock? did you buy it new? from what I understand...the stock 98-00 clutches would slip right off the lot if driven hard.
Old 10-25-2005, 10:13 PM
Bought Used With 123k But The Pressure Plate Looks Like The Zo6 Ones I See. But I Think It Stock. Its Chatters Like A Hoe And Wont Hold When I Grab Second Doing A Burn Off. It Will Light Up 1st But Second No Sir. I Want A Z06 But If Thats What I Have I Want Like A Spec 3+ Or Something. Thanks For The Responses
Old 10-26-2005, 09:28 AM
why don't you just save the time of replacing the clutch again and get something better? i'm babing my clutch till i find out if the ls7 clutch with the ls2 flywheel definatly works well..cause that'll be my next clutch..and i'm pretty much stock, but i know that i'll be doing a 12 bolt with headers and a cam sometime within the next two years and want somethign that will last...will the zo6 work for now? yes, but it'll die once i start to mod and beat on it more.
Old 10-26-2005, 09:47 AM
yea but its cheap compared to the rest. but i guess you get what you pay for too. i dont race at the track or really launch hard. but i do abuse it sometimes dont get my worng. i really want something that will not chatter at all. what ever is in my car sucks hard. it is a heaping pile
Old 10-26-2005, 09:53 AM
SporkLover's Avatar
If you are going with a cammed car, dont waste your time on a z06 clutch, just get the spec 3.
Old 10-26-2005, 10:42 AM
thats prob what i will end up with. i might get the 3+ cause it better on the street suposedly. i am no expert so we will see. thanks for the replys
Quick Reply: how do you tell the diff between LS1 LS6 clutch?
