Swapping heads, cam...pushrod length question
Old 10-25-2005, 07:43 AM
BadAssFast's Avatar
Default Swapping heads, cam...pushrod length question
I'm lucky enough to be getting AFR 205 heads to swap into my stock 2000 Z/28 to go along with my FMS 13 cam. We purchased the kick *** install kit with Manley springs etc...the one unknown quantity so far is PushRod length. Should the pushrods that I got before I got head work with the AFRs or do you think after we mock up a cyl...we'll find a length difference. BTW Futral and TTP have been very helpful - I recommend both companies highly.
(I just reread this and am still cracking up...i'll let it stand!)
Old 10-25-2005, 08:01 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
are they 7.350 or 7.400? And Headwork, I assume you mean milling since you are talking about PR length.
Old 10-25-2005, 08:15 AM
BadAssFast's Avatar
7.4 080 is on the rod
Milling ? No metal work planned.
Replacing stock heads with off the shelf AFR 205s
