New LS1 Owners - Newbie Tech - how to make 500 rwhp
lafws6
10-25-2005, 10:15 PM
i have a 99ws6 with dynomax headers and borla exhaust with a lid and kand n with 373 gears i know i will have to go to a 12 bolt but i was wondering how i could get the hp without spraying.
rdeterman
10-25-2005, 10:16 PM
heads and a large cam
h/c/i, FI, or n20. take your pick.
if your serious about achieving 500rwhp and have the budget i suggest searhing "500rwhp" in the internal and dyno forum.
LvDemKings
10-25-2005, 10:24 PM
the best way to make 500 is to do a search. You might even wanna look at "So you wanna be fast" by jaberwaki at the top of this forum... :)
lafws6
10-25-2005, 10:33 PM
i am kinda new at this but i was wondering if anyone knew how much hp a good head and cam package would give with all the bolt ons , gears, and 3600 stall i am trying to get 500rwhp so i need to know what i need to achieve that
2000taws6
10-25-2005, 10:38 PM
if you wanted to stay N/A you could always stroke it and then do heads and cam and that should get you there. Of course with all the bolt ons.
lafws6
10-25-2005, 10:49 PM
thanks can anyone suggest a good head and cam package to go with i want something with alot of lope
lilstephsls1
10-25-2005, 10:50 PM
budget is a big thing to specify. There are cheaper ways of making 500, and also very expensive ways of making it. You really need to do a seach on different people's setups and how they achieved 500ish hp and see what fits your needs a budget best
2K2WS6TA
10-25-2005, 10:56 PM
You want 500rwhp, go find the posts by PatrickG, he has a H/C T/A that put down 495, with the stock exhaust manifolds, add the 100 shot of N2O and he's putting down nearly 600 :eek:
He's using a Thunder Racings Cheatr H/C package
lafws6
10-25-2005, 11:02 PM
i am not worried about the budget i was wonder if it would be easier building my motor or building a stroker how much would you guees it would cost to have 500 rwhp
Lithium
10-25-2005, 11:24 PM
cam and spray
black00TA
10-25-2005, 11:26 PM
i would spend the $ and get a nice built motor from a reputable company.
and of course allllllllllllllll the support mods. =]
how much u spend depends on you, i personally would spend as much money as possible. :drive:
natronathon
10-26-2005, 12:38 AM
yeah, a nice set of afr heads, and a 230/230 cam or even slightly larger, plus all the bolt-ons should make you close...
'Trust'
10-26-2005, 01:23 AM
yea, just make sure you dont neglect the supporting mods, suspension, rear end, SAFETY equipment, and build up that tranny, w/that much power other than money on the motor you'll need a good 5-6k for the tranny, rear, and suspension (shocks, tq arm, lca's, panhard, sfc's etc.)
lafws6
10-26-2005, 07:56 AM
thanks for all the help will let ya'll know how it goes
OverLord
10-26-2005, 05:32 PM
well there is always the 408ic stoker setup for n2o(300 shot baby) or setup up for a blower. You'll probly need a lil bit more money.
brad8266
10-26-2005, 05:50 PM
500 at the wheels with a stock cube N/A motor seems like a far stretch. Hope you dont plan on driving this car on the street. I would just spray it and be done with it if that all you want to get is 500Hp.
davered00ss
10-26-2005, 05:57 PM
Bigger cubes. Forced induction. Nitrous Oxide.
c0ncEpT
10-26-2005, 06:47 PM
427 LS2 with a big cam and some nice flowing heads will do it just fine
fortunate
10-26-2005, 07:08 PM
im new here,i made 476 with stock cubes,when im done tuning it should be at 485,not quit 500 but close,its in a 03 zo6 and im having idle problems,maybe someone can help :offtopic:
redtail2426
10-26-2005, 07:13 PM
495 from patrick g???I thought it was 395 with the cheater package.I dont think 495 rwhp is possible on stock manifolds??please correct me if im wrong.
429 Mustang
10-26-2005, 07:23 PM
485 RWHP?
Wanna share that setup with everyone here?
fortunate
10-26-2005, 07:49 PM
485 RWHP?
patriot stage 2 heads,595 605 232 238 112 cam,lg long tubes and no cats,under drive pully,electrick water pump,roller rockers,cold air intake,fast intake,ported throttle body,stage 2 clutch and aluminum flywheel.right now my A/F is @ 12.0 but with some more time ill get 12.8 across the board,plus ill do a nitrous pass and hope to see 600.
2K2WS6TA
10-26-2005, 08:03 PM
My bad :( it was 395 thru the stock manifolds, 494 rwhp with the N2O
Here's the thread
http://www.ls1tech.com/forums/showthread.php?t=311937&highlight=cheatr+cam
