30 and 28 jets in my DP kit
7 Second Club
trying to decide if i should run these since they have already been put in....
a 30 N2o and 28 fuel on stock short block... what would you guys do
c14 in dedicated fuel cell
8 second mod
thats alot of spray for stock parts
id be sure the fuel press is safe. set it a bit to the high side.
i went 9.53 with those jets.
The 30's would be 325 flywheel and 22 are a 175 flywheel. I would use a 22 jet for 7.5psi fuel pressure. The calculator sayes 20 so a 22 is one step rich. You can always play with the fuel pressure to dial the system in more.
That's a good start but you could run 32n/28f if you ended up needing some more power. With stock parts I would leave it like you've got it.
