What kinda numbers with AFR 205's and FM13?
Old 10-26-2005, 12:47 PM
joshp14's Avatar
Default What kinda numbers with AFR 205's and FM13?
Current numbers are 368 RWHP on a mustang dyno with a half *** tune. What does my current number convert to on a dynojet? 380? 390? 400?
I have all of the mods in my sig, and I would like to slap on a set of AFR 205 heads (66cc chambers). What kind of numbers would I be putting down at the rear wheels after the install? I plan on getting a mail order tune from Jeff Creech or possibly a dyno tune from a reputible shop after the install.
Old 10-26-2005, 01:47 PM
Hennytime's Avatar
theres a local guy with that setup and a 90/90 intake and makes 462rwhp on a mailorder tune and mike norris's dyno...not to shabby, and he's a m6
Old 10-26-2005, 04:21 PM
joshp14's Avatar
for now it would be on the stock LS6 intake and stock TB...maybe a little in the future I may change to the 90/90.
Old 10-26-2005, 11:10 PM
FstBlkz28's Avatar
A ported stock TB would help out tremendously, especially with heads. You can pick them up for not too much relative to how much it'd help out a cammed or H/C car.
Old 10-27-2005, 01:17 AM
92SilverSHO's Avatar
im guessin at least 430rwhp.
Old 10-27-2005, 10:52 AM
LS1 Tech Administrator
Patrick G's Avatar
Depending on your tune and bolt-ons, the AFR 205s should give you a solid 30-40 rwhp gain along with better streetability. The amount you mill the heads and thickness of gasket used will skew your numbers higher or lower. I recommend a .030" mill and a .045" Cometic gasket.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 10-27-2005, 12:12 PM
joshp14's Avatar
So are you suggesting a mill them after I get them? or would AFR do this for me? When I mill them .030 and use a .045 gasket, what will that leave my CR?
When I did the cam swap we hand sanded the TB out and hit it with some polish...its not necessarily ported though to the best standards. I should probably get one done by one of the well-known porters around here to get it epoxied and such.
Old 10-27-2005, 01:58 PM
Patrick G's Avatar
About 11.30 to 1 static compression. It would be better to have your local machine shop mill them so they are perfectly straight and true by the time you're ready to bolt them up.
Old 10-27-2005, 02:36 PM
GTO_Scott's Avatar
I'm only milling .012 (66 to 64cc) and using a .040 Cometic - With the piston .005 to .007 above the deck, I'll be right at 11:1CR. You'll need to know how far above the deck surface your piston is to figure out CR.
Old 10-27-2005, 04:24 PM
joshp14's Avatar
I dont know how far the stock piston is above the deck...why do I need to mill them? Won't they be correct from AFR? or are you suggesting milling them for my application?
Old 10-27-2005, 07:33 PM
Patrick G's Avatar
Milling the head will raise your static compression. This will increase torque. Using a thinner head gasket will increase static compression and decrease quench...both increase torque. The stock unmilled heads from AFR are 66cc and will give you about a 10.5:1 compression ratio. If you mill them .030", you will pick up another half point in compression which will make more torque (5-10 tq increase). I suggest milling them this amount.
__________________
Old 10-27-2005, 08:03 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
My 346/A4 makes 453 rwhp, but with a locked converter and bunch of other measures that only Allan Futral could tell you about.
Old 10-31-2005, 08:04 PM
joshp14's Avatar
Thats good to know...thanks for the input. Do you guys think that the AFR 205's would be the best for my application? What about the TEA or Patriot? How do those heads' numbers compare to the AFR's?
Old 10-31-2005, 08:19 PM
BriancWS6's Avatar
There is a HUGE ongoing thread that is all about TEA vs AFRs. Check it out.....
Old 10-31-2005, 09:29 PM
SideStep's Avatar
I pulled 440/420 (sae) with the heads in my sig and a F13 (112lsa+4)
Old 11-01-2005, 12:08 AM
FUN LS1's Avatar
If you plan to throw a 100-shot on it down the road, should you reduce the Mill to yield 10.8 CR or less?? Once you get to 11.x:1, what kinds of things do you have to do to protect against detonation? I was looking at the same AFR205/F13 setup (112+4). I don't plan to spin it higher than 6800, and I figured 100 hp out of the head/cam combo, plus I want to add a 100-shot (MAF) down the road. My goal is a high flat torque curve; hp will take care of itself... The torque graph above looks pretty good, I just want to shift the whole curve up about 70 ft lbs.
Old 11-01-2005, 12:38 PM
joshp14's Avatar
I dont plan on FI or nitrous...I want to keep it all motor...so I should be able to keep the compression up there. You will just have to keep the timing retarded and the fuel octane high and detonation wont occur.
Old 11-01-2005, 03:20 PM
FUN LS1's Avatar
Thanks, will that defeat grinding the cam +4, or should you not have advance ground in for NOS?
Old 11-01-2005, 03:33 PM
joshp14's Avatar
I would probably do the +2 or none if I was running nitrous. If you call and talk to Alan @ Futral he will give you a better idea...he advised me to get the +4 when I talked to him back in May when I got the cam.
Old 01-08-2006, 06:51 PM
joshp14's Avatar
What is the piston to deck measurement on a stock internal LS1? Also, what is the compressed thickness of stock GM head gaskets? .052"? And where can I get the correct thickness gasket?
