Untuned LS6 intake...
SSU's Drunk Typing Whore
Would it pass...I am about put back on my stock exhaust manifolds for emissions testing. My car never got tuned, so would the LS6 manifold pass emissions here in Ca. I am almost certain it will, but I want to be sure. Thanks.
If you have the LS6 intake w/egr, then you will be fine. The intake isn't going to alter emmissions in any meaningful way. If you don't have EGR, then you might run into complications.
Originally Posted by FBDYLVR
Should have no problem, the only reason you'd fail w/ an LS6 intake is because they usually don't have EGR (tampering with emissions equipment)
Originally Posted by Slammed99s10
Like everyone has said, it shouldn't be a problem if you have the egr and smog crap hooked up still. But I saw in your sig that you have LT's w/ ory pipe, that might be a different story. If it's just a regular smog check, they'll most likely fail you on visual inspection and you might not pass on the sniffer with the y-pipe. If it's a test only smog check just be ready to grab your ankle's.
I just got done putting on the stock manifolds and cats. Pain in the *** but its done now. Much easier swap this time, took me half the time as when I first installed the headers/ory...still sucked though
Hahaha I wish it only took a couple hours!
It was like 6 this time, first time was double that...mostly wrestling around with the TSP ORY and it being my first time installing headers.
I have not driven around yet, I am looking forward driving around and feeling the difference in power.
The stock **** is going to stay on for a month or so also, I am going to be buying some heads/cam very soon...so I ll swap the stuff back in when I start the install...god I hate emissions here.
Originally Posted by Redneck Z
How does it feel going from longtubes to stock manifolds? How much hp does the butt-o-meter say you've lost? After having done the swap a couple of times now, you should be able to put the LT's back on in a couple hours, huh?
What heads and cam do you have?
Thats definitely a good setup for a DD. Especially with that spring change interval, I had no idea springs could go that long with that cam. I was going to go that route myself, I actually bought two cams now that I have sold...a 224 and a 226 both with a 114lsa..hoping it would pass the sniffer. I never installed them though cause I knew once it was in I would want to go bigger.
I am really considering getting the MS3 or the F14 and some heads. I am not real sure on what heads though, I am trying to work it out one of the guys at TSP right now. I am just tired of worring about emissions and having that hold me back from what I really want to buy you know? So I am just saying F it now and go with a big *** cam. I am hoping in the next two years someone will hook me up with their connection for cheating emissions. Or I will just try to find someone who will take some money to pass me. That not for another two years though so I got plenty of time to figure something out.
Have you looked into the F13? If I wasn't concerned about emissions, I think I'd probably go with this one. This one seems to make more power than the MS3. There is a guy up here than does over 430rwhp I believe, with stock heads. It has great driveability and makes great power. Check it out. The guys on this site that have it, love it.
EDIT: My bad, I just read that you listed the F14. I'm blind LOL.
Hahaha yeah the F14 is also being considered. I am still not real sure though because I dont want to have to flycut when I get heads...I am still trying to get some more info from TSP, they said they have a couple heads that will clear. I am pretty sure that the F14 does not clear most heads either...
