Engine Drop Mods
Old 10-27-2005, 07:22 PM
LC
LC's Avatar
Default Engine Drop Mods
I will be changing Cam soon, since doing it "requires" droping engine oil, droping coolant, removing crank pulley.. etc
I was thinking that if i'm going to do that i would do other mods that require the same things like:
ASP pulley
160 T-Stat
Rod Bolts
Poly Motor Mounts
What other things can be done?
Old 10-28-2005, 06:37 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
you are going to have to pull the motor to do those rod bolts. Looks like you will be pulling instead of dropping!
You wont be able to get the Pan off without pulling the motor so if you were thinking about going through the bottom side to do it.
What size cam are you going to run? Depending on the RPM range you really wont need to do rod bolts. the stockers are probably good enough to hold to about 6800 rpms.
But anyway to answer your question:
Timing setup : LS2, cloyes, rollermaster
LS6 ported/blueprinted oil pump
Springs , retainers, pushrods.
Maybe a stall if you are doing anything over a 224 cam.
LS6 intake or FAST if you got the cash.
Hope this helps.
Old 10-28-2005, 08:38 AM
GuitsBoy's Avatar
you can keep the engine in, but it requires dropping the K member atleast... probably wont save you much effort vs. pulling the engine though...
Old 10-28-2005, 10:08 AM
Big Geek's Avatar
I started with the springs and retainers, then the cam. While I was at it I went ahead and installed a blue-printed LS-6 oil pump and LS-2 timing chain. I also deleted the EGR and AIR jungle. Be forwarned, should you decide to replace the oil pump make sure to get at least two new oil pump pick-up o-rings if your luck/skill is not always up to par. Not only did I fubar the old one but one of the new ones as well. Good luck to you.
Jim C.
Old 10-28-2005, 03:02 PM
LC
LC's Avatar
Thanks guys, well springs/pushrods/retainers are a must.. I'm going MS3.. I will also be getting 4.10s so i want to rev 7000+ if power is there..
What are the benefits of LS2 Timing combo?
and What is the benefit of a LS6 oil pump?
Thanks!
Old 10-28-2005, 03:08 PM
BAD FNZ's Avatar
Correct me if I'm wrong, but can't you drop the k-member and jack up the blcok and change the rod bolts on a vette?
Old 10-29-2005, 02:27 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Maybe so, but the truly easiest way is to have the engine out. You would almost need a lift to do it with the engine in, but yaeh regardless K-member has to come out.
