injector flow rate calculations ?
I can't remember offhand the reason for not using a straight multiplier for new injectors. I used RedHardSupra's blogspot to dial my injectors in.
http://redhardsupra.blogspot.com/
I downloaded the excel spreadsheet and copied the calculated #s from there.
can't use a astraight multiplier... but there's been some questions regarding what ford actually rates their injectors at...
All this info is in the sticky's
he has a fuel rate chart listed for SVO 30 lb injectors on that website, but it's for injectors rated at 43.5 lb of pressure...I called SVO 3 times in one week to ask them about the rated pressure for their injectors ( I called so many times to see if I got the same answer each time), every time I called I got a different person and they all said 40lbs, if they're lyin at least they're consistant
then use the spreadsheet to use it with 40psi as their rated pressure, no big deal there. all i know that i had my stockers in, ve tuned in pretty much perfect, swapped injectors, put in new IFR based on the 43.5psi rating numbers, and the trims didn't change at all, car ran perfect right away, the only thing that changed was the duty cycle.
sorry, i've been awefully busy lately. my guess would be that i probably used 58.02psi for my 4bar conversion, as that's what it is precisely speaking. that would be the source of the minute differences. use the spreadsheet, try it, maybe that will explain a thing or two.
when you paste in the tune right? i just think that you have to be in a certain number range. i know that some settings i go to chagne if i put it at 1.99 it may save it as 2.01 or 1.96. its kinda weird but maybe it has a scale it has to follow and just goes to the closest value? still havent been able to figure that one out
