BMN Window Switch Just Went Dead???
Just came home from the dyno, did one pull with 150 shot. I changed the turn off setting, then all of a sudden the switch would not work anymore. The red light won't come on, it wont spray, nothing. I checked all the connections, they are fine. Went through my fuses, all check out ok.
Any ideas???
I am at a loss.
Thanks,
Jason
Any ideas???
I am at a loss.
Thanks,
Jason
Originally Posted by Nitro Dave's Nitrous Outlet
Jason, The unit was working one minute and not the next? Did you change anything.
Dave
Dave
Correct, the only thing I changed was the nitrous shut off dial.
Make sure neither of the dials are "between" the notches/settings. In other words, make sure you hear/feel the click so that you know it's not in between rpm points.
Also, did you use a tester to see if the "hot" wire leading to the switch actually has power going to it?
Made sure the dials were in the correct place, and not in between.
No, I don't have a tester...I guess I need to get one. I am gonna try replacing the relay, maybe that could be it???
Dave
Dave
Dave,
Have you known of any of these controllers going bad? The red light comes on, but it is very dimm. When I blow on the unit, the light goes off, then comes back on when I blow on it again. Could the unit have gone bad?
Thanks,
Jason
Jason. That is crazy.LOL It sounds like the unit has went bad. I would get with BMN and send it back to Bill for him to check. Call me if I can help.
Dave
Dave
Dave,
They don't have a phone number on their web site...so I sent them an email. I'm sure they get a ton of emails a day, I hope they respond soon with what to do.
Thanks for the help!
