Does a truly "Stealth" cam exist?
Old 10-28-2005, 07:39 PM
KB99WS6's Avatar
Default Does a truly "Stealth" cam exist?
"Stealth" cams may sound stock out the exhaust but b/c of their aggressive ramp rates & high lift you need HD springs and this makes for a lot of valvetrain noise.
My cars under warranty if you know what I mean and want a truly stealth cam, that will still add a decent amount of power over my stock LS6 cam.
Want to do a totally stealth H/C setup. will be run through 100% exhaust including stock manifolds. Only visible/noticeable mod will be the vararam. Possible?
Old 10-28-2005, 07:47 PM
CaptUSA's Avatar
The shop is going to be able to tell you've got aftermarket Heads on the motor at a glance.
I'm sure there are cams out there that will fill your need, but I'm not an expert. Just get one on a 116-118 LSA, and you should be good for idling sound. Don't know how much power you would be leaving though. How long until your warranty expires? An '01 is 4 years old. Did you pitch for the 5 year?
Old 10-28-2005, 07:50 PM
KB99WS6's Avatar
I just extended it another 4yrs/32k miles today for $1290. Major Guard GMPP warranty. The heads are PP stage 2 LS6 heads. If patriot doesnt put any markings on them how can they tell?
Old 10-28-2005, 08:02 PM
ninobrn99's Avatar
the old man cam...mti's stealth cams...a few other are out there..you can also get a custom cam with a cam with a .570 lift or less since the ls6 springs are good to .575 and then a 115+ to tame the idle. then you could go up to a higher duration intake and exhaust.
Old 10-28-2005, 09:37 PM
ArcticZ28's Avatar
Why spend all that money to get 1/4 of the power from the mods with your restrictions?
Old 10-29-2005, 01:49 AM
CaptUSA's Avatar
All he needs is More Cowbell!
Old 10-29-2005, 04:36 AM
ArcticZ28's Avatar
You think you know, but you have no idea. Mod money is my cowbell. This is the true life of ArcticZ28.
Old 10-29-2005, 05:21 AM
PREDATOR-Z's Avatar
What a lot of us forget is that "Stealth" is relative to exhaust used.
The quietest non OEM system is cated with Magnaflow muff.
I've had 3 exhausts with my Stealth II cam and the one above is the most stealthy at idle, untill you open it up of course.
Old 10-29-2005, 11:44 AM
BURN'EM's Avatar
Spray it! cheap and easy to remove for service.
Old 10-29-2005, 01:07 PM
11SECSS's Avatar
did you get a aftermarket warranty or one from the dealer.
Old 10-29-2005, 01:58 PM
Moderator
davered00ss's Avatar
My TR224 is prety stealthy. you cannot tell there is a cam in there by sound.
Old 10-29-2005, 04:43 PM
Rob
Rob's Avatar
The LPE GT2-3 is about as stealth as you can get. Even comes with GM springs. No noise up front and no noise in back.
Old 10-29-2005, 04:45 PM
slowpoke96z28's Avatar
because LS6 heads have a different casting #.
BUSTED
sorry. if you are worried about warranty, spray is the way to go, especially if you bought the car used(you could claim abuse was because a previous owner).
