dissapointing results!!
i have recently converted my LuminaSS (GTO) from A4 to M6 and went with a G5X1 cam on comp springs.
took it to the dyno to see what it will put down. and i was a bit suprized with the result! before the conversion and cam i was putting down 340rwhp 344rwtq with the LS6 cam i had and stock tune. now, im putting down 358rwhp and 355rwtq with a tune :Confused:
my afr is close to 12.8 and my timing is reading 27-28* with no KR.
does that seem normal to you?
Just a couple things to check. How is the condition of the engine? Compression leakage etc....
Also could the cam be installed wrong??
If the motor has a reasonable amount of timing, which you do, an AFR which is close, which you do, then there is no reason tuning wise it shouldn't be making power. Despite all the parameters and tables the bottom line is the timing and fuel are OK.
Same dyno??
Same dyno??
