advanced turbo tech
advanced turbo tech
ok so we all knw the basics.. exhaust is pushed out of the cylinders and through the turbo to turn it. heres my technical question. with the right setup, wouldnt the trubo be on the verge of creating a vaccum to suck out said exhaust or already be causeing a vaccum? and on that note, how can you tell if you actually are getting all of the exhaust out or is that not technically possible? it seems that you would want a very small amount of overlap to use the boost to push whats left of the exhaust out to make a more efficient burn. i dont know if what i said is physically possible but it just makes too much sense.
go to the forced induction section and read the sticky about FI.and go to www.forcedinductions.com and read turbo 101.
Originally Posted by DeltaT
The turbo operates more off the intensely hot and expanding gases to turn the turbine, not just the flow of the exhaust over the vanes.
Jim
Jim
Originally Posted by Ryan K
Um, One word, NO.
When you realize that a Turbo charger "typically" creates exhaust pressures 2 to 3 times the Intake charge, there is no way that a turbo system will create any scavenging effect.
Ryan
Ryan
