high and low oct tables
Old 10-29-2005, 11:45 PM
zrater's Avatar
Default high and low oct tables
how can you no what table its using when im scanning and replaying
the log. thanks
Old 10-29-2005, 11:52 PM
SSpdDmon's Avatar
I know in EFILive there's a pid called "aspark" that tells us how much of a swing there is between the tables.
Old 10-30-2005, 12:09 AM
LS1TECH Sponsor
Magnus's Avatar
THe correct parameter you are looking for is called Knock Learn factor. It is in the VCM Scanner.
Old 10-30-2005, 08:10 AM
Moderator
jimmyblue's Avatar
The spark interpolates, on a sliding basis, between
the two tables (not just one or the other). The KLF
is your "slider". 1.000 = high, 0.000 = low, otherwise
the spark value will be in between, something like
(KLF*HO)+((1-KLF)*LO) for the base value. If you
have a ping history then you will see fractional KLF
values (only getting to 0 if you're pinging most
heinously, and 1.000 only if your spark tune is
pristine (or overly conservative).
