switch from LS1Edit to EFI live
I have checked the "search" function and have not found the answer. I have had my car tuned with LS1Edit, and I own the cable/software for my car. My question is if I want to switch to EFI Live, are there any issues? For example, my original tune was by EdWright, and when we made the first flash with my then-new LS1Edit, the PCM smoked. Is this an issue with EFI Live after LS1 Edit. Thanks for your patience with this likely already asked question!
No one is saying EFILive is better than HPT or vice versa. Both packages are better than Edit now which one you choose is totally up to you and your needs. I went with EFILive for many reasons. Reasons, a quick search or a skim of the stickies will uncover
Originally Posted by HumpinSS
No it isnt and you also get a credit towards your EFI purchase when you trade in your edit cable
I went from LS1Edit to EFILive FlashScan with no problems. It takes about 30 seconds to flash the PCM. Edit took 2-3 minutes.
Go to http://www.efilive.com/
Bill
Bill
Originally Posted by TLKSCHP
I don't see anything about being able to trade in ls1 edit, I thought that ended in September.
How much $ are they allowing for the trade in?
Originally Posted by EFILive
EFILive is offering a free upgrade from Personal to Commercial (worth $150) or 2 extra PCM licenses (worth $198) when you send in your HPTuners or LS1Edit cable.
That means you only need to purchase the personal version for $699 and you can upgrade free to the Commercial version (worth $849), or you can have 2 extra PCM licenses (a total of 4 including the 2 that ship with EFILive) for trading in your HPTuners cable.
Regards
Paul
Regards
Paul
