which master cylinder
ok just bought a ls6 clutch kit (clutch, pp,flywheel) also ls6 slave cylinder w throwout bearing which master cylinder should i get. does anyone know the part # for the new gm adj master cylinder
Originally Posted by silver98formula
I have the Mcleod adj. master in mine and I love it. As Zeus said, it has a bigger diameter than the stock one.
Chris
Chris
For the same reason it should also be harder to push. Can you notice that?
I dont know if the master cyl. incresed pedal presure or not. I swaped from a spec stg. 3 clutch to the Mcleod dual disk. I know there is ALOT more pedal pressure but I imagine it is from the different clutch.
Chris
Chris
Originally Posted by sgarnett
The Ram adjustable MC is a modified stock GM part.
Originally Posted by Assassin
dude, your useing a stock clutch, use the stock master if you dont want to spend money.... just make sure to do the drill mod!!!
