Sponsor Sales & Specials - Moser 12 Bolt Sale at Exotic Performance Plus! $2,350.00 with options!
EPP
10-31-2005, 06:45 AM
http://www.exoticperformanceplus.com//images/servicesImages/Adam%20Henderson6.JPG
Our Price:
Moser 12 Bolt with Truetrac, your choice of gear ratio
Moser 33 spline axles (10 year warranty)
Moser ABS (3 channel) or ABS/TCS (4 channel)
Moser Performance Cover
Total price: $2,350.00 + freight collect shipping
Here are Moser's standard prices:
Complete 12 Bolt w/Limited Slip (less brakes) $2249
Torque Arm Cars & coil Spring Rears w/Rears
Includes 12 Bolt Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Eaton Posi or Truetrac Limited Slip(30 spline), Pro Street gears, 1350 series pinion yoke, chrome cover and assembly
* Add for 33 spline Eaton Posi-Unit $100
* Add for 33 spline Truetrac Limited Slip $65
* Add for Performace Rearend Cover $135
* Add for 3 channel ABS setup $100
* Add for 4 channel ABS setup $100
* Add for new exciter rings $75
installed on axles for 4 channel setup
* Subtract for 1310 series pinion yoke -$35
REDSS01
10-31-2005, 07:11 AM
Correct me if I'm wrong...it comes w/exciter rings installed on axles for 4 channel setup + backing plates, or do we still need to send ours(backing plates)to get put on the rear end?
Smartass6885
10-31-2005, 05:06 PM
yeah. i dont want to send my backing plates in unless i absolutely have to.
John02SS
10-31-2005, 05:58 PM
The moser doesn't come setup. you have to assemble with your backing plates when you get the rear end.
John
EPP
11-01-2005, 05:26 AM
Moser sends the rear-ends with the center section and the cover installed. The axles are shipped uninstalled, and you remove your old axles to reuse your old brake backing plates. The backing plates are installed on the new Moser rear-end, and the axles are slid in from the ends. Moser sends installation instructions with the rear-end.
The 4 channel exciter rings can be reused from your old 10 bolt, or Moser can supply new exciter rings for an additional $75.00. When we install these Moser 12 bolts at our shop on customer's cars that have the 4 channel option (ABS/TCS) we reuse the old exciter rings, it's pretty easy to do if you have access to a press. Most Napa shops can do this for you. Bob
EPP
11-01-2005, 05:27 AM
Moser sends the rear-ends with the center section and the cover installed. The axles are shipped uninstalled, and you remove your old axles to reuse your old brake backing plates. The backing plates are installed on the new Moser rear-end, and the axles are slid in from the ends. Moser sends installation instructions with the rear-end. Bob
EPP
11-04-2005, 05:49 AM
Two day turn around on Moser 12 bolt rear-ends! Bob
P Mack
11-06-2005, 10:56 AM
Do these come painted?
EPP
11-09-2005, 06:03 AM
No they don't, they come unpainted just like the factory 10 bolts do. Bob
EPP
11-12-2005, 08:26 AM
We had one customer paint his new Moser 12 bolt at our shop prior to us installing it. We were installing an ATI ProCharger as well, so he had time for the paint to dry. He used POR15 and brushed it on. We left it sit out in the sun and it flowed out really nice and looked great. Bob
Public
11-12-2005, 10:00 AM
POR15 USED to be the best stuff ever, then they changed the formula and it's not nearly as good as it was. I heard it was an EPA thing over solvents or something.
EPP
11-12-2005, 04:29 PM
That's too bad! I hadn't heard about that. Bob
TransAm2002
11-12-2005, 04:35 PM
Price to 89074. Thanks. :)
EPP
11-14-2005, 01:43 PM
Henderson, Nevada would be approx $100.00 for shipping, which is shipped freight collect. You would be looking at a total of $2,450.00. Thanks for inquiring. Bob
EPP
11-17-2005, 07:23 AM
Moser 9" rears also at great prices! Bob
dnm12
11-20-2005, 01:55 AM
what would pricing be to 95521 also i have heard that the Moser's 12 bolts have issues with aftermarket torque arm bars (I have a 98 z/28 6 speed), so much so that BMR has a warning about it on their website. But I would very much like to get a 12 bolt so please let me know
EPP
11-22-2005, 10:03 AM
Roughly $125.00 for shipping to you in Ca, the shipping is paid freight collect when the rearend arrives to you.
We use four grade 8 bolts for the torque arm mounting, and use plenty of red loc tite. We don't have a problem since we started using loc tite on the bolts. I would recommend periodically checking the bolts as a regular precaution. Bob
dnm12
11-22-2005, 04:06 PM
"IMPORTANT NOTICE TO MOSER 12 BOLT USERS: This product is only warrantable on rear axles that utilize the factory style "through bolts" to connect the torque arm to the rear end. Moser 12 bolt rear ends utilize a threaded bolt hole that has been proven to have bolt retention issues when used with aftermarket torque arms. If you have this particular rear axle, understand this warranty disclaimer and still wish to use this product, keep in mind that lock washers, or Loctite brand thread sealants are not substitutes for periodic bolt inspection."
That is taken directly from BMR who sells Moser as well, so basically i have to make sure that these bolts are tight always, how often? thanks
EPP
11-22-2005, 04:48 PM
I have found that once every other month if you drive the car hard, and if they are always tight when you check them, then you can back off on checking them. Bob
dnm12
11-23-2005, 01:46 PM
hmmm....i need a call from you Bob i called and talked to someone else there my name is Dan
MattZ28
11-24-2005, 04:46 AM
Hi Bob,
Can you please e-mail me with a shipping rate to 34990. Thanks.
unwrittenlaw6787@yahoo.com
Matt D
11-25-2005, 08:21 AM
PMed you
MattZ28
11-25-2005, 09:19 PM
Bump..I need a rear ASAP. Tried calling all day but no answer..
MattZ28
11-26-2005, 10:49 AM
What's going on? Still on answer when I call...
SSpeedracer
11-29-2005, 02:20 AM
Placed an order yesterday. What size torque arm bolts do you recommend? What size breather tube is needed? Thanks.
