valve clearance??
valve clearance??
Will i have any issues with valve clearnce with the Thunder racing Cheater cam. 214/230 .601/.578 117 LSA I would like to use patriot 5.3l heads but i may use patriot ls1 heads if clearce is an issue. I am not going to be able to cut the pistons as this is a daily driver and down time has to be kept to a minimum. I already bought the cam so please no recommendations on using other cams.
Thanks
Dan
Thanks
Dan
