finishing heads/cam install--need help ID'ing a few things to connect
Old 11-01-2005, 05:45 PM
CoronaL's Avatar
Angry finishing heads/cam install--need help ID'ing a few things to connect
Well this whole process took months instead of days. Working 80+ hrs a week left little time to work on car . Anyway, can u guys help me identify a few connections/hoses, vacuum lines and a broken sensor I found stuffed out of the way from previous owner! I named the pics with the questions I have, see comment on pics pls.
thanks
Attached Thumbnails finishing heads/cam install--need help ID'ing a few things to connect-broken-sensor.jpg   finishing heads/cam install--need help ID'ing a few things to connect-broken-sensor-behind-clutch-slave.jpg   finishing heads/cam install--need help ID'ing a few things to connect-vacuum-port-here-air-i-deleted.jpg   finishing heads/cam install--need help ID'ing a few things to connect-not-sure-what-attaches-vacuum-line-back-intake.jpg   finishing heads/cam install--need help ID'ing a few things to connect-not-sure-whre-goes.jpg
Old 11-01-2005, 06:02 PM
SPANKY LS1's Avatar
That hose in the last pic goes to that port on the back of the intake, and into the brake booster....
Old 11-01-2005, 06:05 PM
SSU's Drunk Typing Whore
Lithium's Avatar
last pic is the brake booster line (I believe) goes into the back of the manifold and the other side goes by the drivers side firewall...by the brake fluid resivoir...I am pretty sure atleast.
Congrats on the install!!!!!!!
Old 11-01-2005, 06:11 PM
oange ss's Avatar
1st pic = no idea
2nd pic = no idea
3rd pic = looks like AIR control valve needs connected to a manifold vacuum source
4th pic = MAP sensor assy , brake booster hose (last pic) gets connected to the big barb fitting
Old 11-01-2005, 06:16 PM
silverZ98's Avatar
1st pic looks like a very broken temp sensor that goes in side of head. but not sure.
Old 11-01-2005, 06:18 PM
ninobrn99's Avatar
when i first looked at it, i thought 1 and 2 were the iat mod with the resistor, but if you said it was broke, then i dont think its the one that goes to the lid.
Old 11-01-2005, 06:35 PM
CoronaL's Avatar
yeah #1,2 are a sensor I found stuff behind the drivers side hood hinge/strut area, kind of back where the clutch fluid would be filled at. :O
I was like wtf is this :O.
CoronaL's Avatar
also, since I deleted my EGR and AIR, what should I plug that vacuum line at that port?
thx
Old 11-01-2005, 06:38 PM
ninobrn99's Avatar
u mean the one in the back of the manifold?? if so, then no. Its a thin vaccum line that plugs on to that and the MAP sensor is the other. the long hose will go from the back of the intake to the brake booster. the third pic, im not too sure about. i dont remember ever seeing that one.
Old 11-01-2005, 06:41 PM
ninobrn99's Avatar
wait, looking at it more and more, pic 3 plugs in to the tiny vaccum in the back of intake manifold under the MAP sensor.
Old 11-01-2005, 06:49 PM
oange ss's Avatar
see quote under "Pic 3"
if you dont have AIR or EGR, then remove that valve and associated vacuum tubing
Old 11-01-2005, 06:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That would be on your drivers side head...yes. That is what that is. plus it is pretty close to the master cylinder. And when doing a head swap I take it out so i don't break it at all.
Old 11-01-2005, 06:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That little section of wire is really short, you would be hard pressed to strap it to the fuel rail if needed.
ninobrn99's Avatar
damn it! now it looks like it think you may wanna get that one replaced.
Old 11-01-2005, 07:00 PM
ninobrn99's Avatar
i guess i just thought that cause of the resistor
Old 11-01-2005, 07:03 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah I did too at first. (I had to look at those pictures like 5 times a piece) But you can see where the wire was cut on there right at the end of the resistor.
Old 11-01-2005, 07:10 PM
ninobrn99's Avatar
well i saw the shape of it and knew the iat is also a small one, but just didnt think about the ect and it makes sense since its a bit closer too
Old 11-01-2005, 07:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Speaking of looking several times. I noticed that there is over spray on that pic #1 and was this car ever wrecked?
Old 11-01-2005, 08:30 PM
CoronaL's Avatar
good question
carfax was clean, but I've found areas of spray so I am guessing it was hit, but doesn't seem like it was bad. Supports, frames etc... are all good. Whoever put it back together did an ok job, bodywise. Mechanically, this car has been a pit though. Should be a good ride when I get her done though. Payed $12k for it this summer, not bad for a 2000 WS6 optioned with 42k miles . Even if it does need work, that's ok, has been an interesting learning experience.
Old 11-02-2005, 10:25 AM
CoronaL's Avatar
AM bump for more comments!
Also, i need Air blockoff plates for the MAC headers I bought, since I deleted AIR! I need to cap the tubes etc... where can I buy these?
thanks
