trans line thread size
Old 11-01-2005, 06:56 PM
01badbird's Avatar
Default trans line thread size
getting ready to run trans lines to trans cooler and need thread size at trans to get adapter to -6 AN. any help would be appreciated so I don't spend more time running around then to do the job.(already blew rubber hose once not again)
Old 12-10-2005, 07:32 PM
Jimmy P's Avatar
TTT
I would like to know this as well.
How will you be attaching the AN line to the trans cooler?
Old 12-13-2005, 08:19 AM
24v
24v's Avatar
I know on my GTO it is 18mm. I would imagine it would be the same on an fbody? The kit that came with my b&m cooler had 16mm.
Old 12-13-2005, 10:26 AM
EDS01SS's Avatar
sorry cant remember what size it was right now but if possible pull the fitting out and take it with you to have the hoses made thats what i did. If somebody hasnt posted the answer by the time i get home tonight i will check my reciepts.
Old 12-13-2005, 10:54 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
On th 4l60E I am 99.9% sure that the size needed for those fittings on the passenger side are 1/4" NPT. Is that what you are looking for??
Old 12-13-2005, 10:24 PM
Heartless's Avatar
I spliced my tranny cooler into the return line out of radiator (fluid passess thru radiator first) ..... I used earls aluminum plumbing parts, the fittings for 5/16 tubing worked fine to make splices into tranny lines.
