Engine --advice for set-up
I bought this engine from a guy who said he ran a 11.94 with this same engine in his full sized monte carlo. I was wondering how much horsepower this combo should make. I have a 67 camaro this will be going in. I also wanted to know is there any part that would work better with my combo. Like a different cam or intake. I'm looking to get the most power with this set-up. Any help will be great. Could this motor also hold up to nitrous maybee a 75-100 shot. Thanks - Mike
355 sbc engine
10.6 compression
speed pro hyperutectic pistons, teflon coated skirts
eagle cast crank
eagle sir i beam rods
comp cams solid flat tappet cam 532/555 lift 106 lobe, duration @.50 250/260
Dart 200cc iron eagle heads, 63 cc chambers
Wieand stealh intake
trickflow chrome moly push rods
355 sbc engine
10.6 compression
eagle cast crank
monte carlos are heavy and about as aerodynamic as a shoe box, the camaro should be a little lighter, and the cam sounds good...i would consider a edelbrock victor series intake personally, not a fan of the wieands, what kind of rocker arms are you using? I would get a set of 1.6 rollers on there if they arnt already on, and how big are the headers? carb? is the motor a 2 or 4 bolt main? if it is a 4 it should handle a 100 shot with no problems...
I say it looks pretty good. I personally would want a cam with a little more overlap and lobe seperation, maybe a 270/280ish with about 110 lsa. But the cam sounds good for a street car. I would also go to victor jr. and some roller rockers. I would be careful about using the 1.6's though. I used a .500 lift cam with the same pistons and have very little exhaust valve clearance. So 1.6's might overdue it. Good luck.
I'm running a set of the Speed Pro Hypers, and am running .688 lift with over .120 valve clearance.
Isn't the Stealth a dual plane?
If so, go to a single plane if spraying, as a dual plane has def. mixture issues. 100 will not hurt, unless you lean out or under octane.
