3rd gear on STOCK M6 feels a little notchy
my gears are the same.
I think the T56 is just a notchy transmission. It hasnt gotten any worse for the last 15k miles so thats why I think that is just the way it is
sometimes that alum. third gear fork bends, or that pad on the fork wears down. my car hated 3rd and wouldnt even go into 5th because of 3 dollars worth of plastic pads that go on the forks. when you bang gears hard, its hard on the pads, and if you crack one, your dealing with a ton of labor for a 3 dollar part. as far as i know, no one makes better pads, but a pro 5.0 shifter can save cracking pads by setting the stops on the shifter
