anyone make this part
Old 11-02-2005, 10:54 PM
Spenser309's Avatar
Default anyone make this part
A connector which takes the Red and Blue PCM connectors and allows them to be extended and then plugged into the stock PCM?
Old 11-06-2005, 11:14 PM
Spenser309's Avatar
anyone?
Old 11-07-2005, 01:17 PM
kbracing96's Avatar
I would check with Speartech------>>>>
They could probably make you something, but doubt it wound be cheap
Old 11-07-2005, 01:56 PM
slow's Avatar
nobody makes one that I am aware of.
I have thought of cutting the connectors off a junk PCM and then soldering to a harness ends from a normal pcm harness, way too much work just to run a 99pcm in my 98 car.
Ryan
