Need Help On Nitrous Install!!!
Old 11-05-2005, 12:40 PM
stangkiller99ss's Avatar
Default Need Help On Nitrous Install!!!
i just got a NX mainline kit and i have no clue how to hook any of the silonoids up or where i should cut the fuel line to put the t-bar in.
its a 99 ss camaro
Old 11-05-2005, 04:29 PM
SPEEDYws6's Avatar
On your car you shouldn't have to cut the fuel line, you connect the line to the factory test port after removing the schrater valve.
Old 11-05-2005, 04:40 PM
BlownChevySS's Avatar
Hope this helps.
Old 11-05-2005, 10:40 PM
BadAssFast's Avatar
its a 99 ss camaro
STOP what you are doing...some of us have been where you are. At least SEARCH these threads before you make unnecessary problems for yourself. Send a Private Message to Nitro Dave or NXRicky. Look in the FAQ thread. Download instructions from NX's site.
Originally Posted by BlownChevySS
Hope this helps.
Add a FUSE at the battery too.
Old 11-06-2005, 08:33 AM
XTrooper's Avatar
Don't you have an instruction manual? If so, read it. If not, you need the instructions which, as Macon stated, you can get from the NX web site.
Click here and download the instructions for your kit.
http://www.nitrousexpress.com/Instructions/main.htm
Old 11-08-2005, 12:43 AM
electricz28's Avatar
Get a rpm window switch a must on any NX app.
Old 11-08-2005, 11:00 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
If the mainline kit does not come with the braided line you need to connect to the fuel rail let us know as we stock them $29. www.dynotunenitrous.com
Cheers
Dan
Old 11-08-2005, 11:05 AM
Nitro Dave's Nitrous Outlet's Avatar
The mainlione kit is the bottom of the barrel.The problem with that kit is that you will need to purchase a few more things to get it to work correctly on the lS1. IF you need somehelp I know exactly what all you need. Give me a call.1-866-648-7637.
Dave
