What clutch are you guys running?
I think my stock clutch is going south. What are the rest of you using that is holding at least 500HP/500TQ? I only want to do the replacement once, so any input would be appreciated from those of you making big numbers with a blower.
i had a spec 3 clutch in when i had my heads/cam, held wonderful. Im selling that now because the new setup will blow up the clutch. Ive already put in 2 new ram vds900 clutches that blew up, so im stepping up to a mcleod twin disk setup.
If your interested in a barely used spec 3 that is rated to 680 hp or so, im me
Thanks, and good luck with your setup.
