wtb parts for 98 ls1
i'm looking for springs reatianers and locks good up to a 600 lift a new ls6 timing chain, ls6 oil pump, a stage 3 clutch and flywheel and a tnt f1 kit or f2 ,some 17" nitto drag radials ,also would like a aftermarket intake and throttle body would settle for a ls6 intake let me know what you have and how much
That's what she said...
go by a stealership and get an LS2 timing chain, thicker links, but still works with stock sprockets.....
SDPC has them for about 30 bux
where the hell is local for you? zavalla texas is a stretch on these parts, but houston texas isnt....
.....or you could just get overnight parts from japan
If you limit yourself to local pickup, you're definitely not going to get all those used parts within the week. Within a month even.
With that said, I have a Weiand intake, drilled with direct port. For 90mm TB. I also have BFGoodrich DRs, but in 18s, and mounted on BBS RG-R wheels. The whole set of 4 is for sale - 18x9.5 front and 18x11.0 rear, with 275 and 315 Pilot Sports, and the 295 DRs. The bolt spacing is for a C4 but the offset is kinda whacky, as they came off my Honda.
