VCM Scanner 2.0 - Not allowing me to assign a user defined WB to Air Fuel Sensor
I had no problem doing this prior to transitioning from 1.7..
My wideband uses a non linear curve, therefore i have set it up and been using it in the Scanner with a list type function. It is set up as one of the user defined Aux inputs, and I set the sensor option to Air Fuel Sensor.
The problem is, even though the wideband's output on the EIO PID is correct, trying to get an output from Air Fuel Sensor or logging Air Fuel Sensor shows 0.0.
This is a major pain in the *** because I would love to be able to use the wideband in Air/Fuel Percent Error but i can't because that is looking for Sensor 120 which the wideband is not being routed to.
Any input?
Any input?
