General Maintenance & Repairs - Head Removal issue
phinger
11-07-2005, 08:34 AM
hey all, new here. i have a 95 camaro z28 with LT1.
no mods...other than the cam for now
has new cooling system, new opti, new front end of motor, new bottom end. comp cam installed.
now the head gaskets are toast...so im replacing them now too.
motor is still in vehicle.
i got all the bolts out. now the heads dont wanna move at all.
what do i have to do to get these things off without damaging them?
RealQuick
11-07-2005, 08:44 AM
I use a rubber mallet and a small block of wood. i put the wood against the surface the inatke manifold would bolt to and whack it. Sometimes I just whack it with the rubber mallet in the smae spot. DOUBLE Check the bolts are off. On the passenger side, make sure the bolt from the accessory bracket behind the power steering pump isnt still bolted to the front of the head!!!
phinger
11-07-2005, 08:48 AM
shoooit...i gotta take that PS pump off???? rrrrrrrr
Chris 96 WS6
11-07-2005, 09:20 AM
You at least have to take the PS bolts out because they go through the bracket into the head. 10mm deepwell through the hole in the pulley will get them. Can't remember if there are 2 or 3.
RealQuick
11-07-2005, 10:04 AM
There are 2 bolts holfind the ps pump on, then you can cock it to the side and read the one accessory bracket bolt that goes to the head!!!
RealQuick
11-07-2005, 10:05 AM
guess you didnt get every bolt :judge: :jest: J/k!
SmokedOutZ28
11-07-2005, 10:10 AM
Did you get the lines off the back of the heads???
phinger
11-07-2005, 11:01 AM
i got everything off the front of that motor stripped. so the heads are cleared to go.
i did not take the back thing off, one of the bolts is stripped somehow, so im gonna yank both heads off at once.
now how do i get those heads loose from the block?
zlightning
11-07-2005, 04:51 PM
Like they told you hit them with a rubber mallet.
phinger
11-09-2005, 02:52 PM
ok, i got one off...the dirvers side.
the pass side i still had some bolts in because i know it was gonna not be fun.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
