What would happen if I
just replaced my my clutch and didn't upgrade my hydraulics? I guess im going to just get a z06 settup for now. seems cheepest the car is only going to have L/T headers,ORY,slp catback,lid for the next year! untill i get back to the mainland
the cari s a 99z28 thanx
well you could do that with no problems. until your slave goes out then you have to pull tranny out again to do it again. i am tight *** so i will run mine till it doesnt work then fix it. dont leak or anything i would run it. although the 01-02 updated slave seem to have a lighter pedal pressure and compress a stiffer clutch easier. but you are going with the ZO6 you should be fine. thats what i am going to do anyways.
1 Post
Originally Posted by 2002ssmalibu
well i might get the slave but not the master is that ok?
i will the clutch now isnt that bad just slips when on it reaLLY hard on 1-2 shift ither then that its fine. Im going to be ording it soon so i will just keep it sitting to side until i need it How do you think it should last with little track passes and a good driver?
