Generation III External Engine - SLP Longtube Nightmare
BrdofPry
11-07-2005, 09:45 AM
Can't install passenger side header, :bang: the instructions are not helping very much at this point. Anyone have any tips? suggestions? magic spells? any help would be greatly appreciated.
02BlackBullet
11-07-2005, 09:51 AM
I think nightmare is an understatment when installing the SLP headers. The install blows ass. There is only ONE way to get them up there. I would love to help you but the headers stressed us out to a point of drinking beers every few minutes during the install and by the time it actually butted up to the block and went in correctly...well...I don't remember.
The best advice I can give is to mess with it untill fustrated and take a break from it. Getting pissed will only make it that much harder.
...I thought the driver's side was the hard part.
Flaminchiten67
11-07-2005, 10:16 AM
Try unbolting the motor and jacking it up a couple of inches.
02SOMWS6
11-07-2005, 10:23 AM
I ended up hammering the body a little were they hit. The passenger side was hell.
BrdofPry
11-07-2005, 06:04 PM
Ill try again tonight, thanks for the info guys
red6speedss
11-07-2005, 06:12 PM
are you installing them from the bottom? My pacesetters fit right in place from the bottom.
tmw00ss
11-07-2005, 06:25 PM
You have remove the motor mount bolt & jack up the engine a little also you can remove the transmission crossbace & pry the shit out of the transmission towards the drivers side. Good Luck
take the bolt out of the motormount.
Then jack the engine up on an angle.
You will have to play with the height of the motor...going up and down a few times...it will go in just make sure you have one other person other than yourself.
00sscam
11-07-2005, 08:00 PM
I was able to install them by unbolting the trans and the cross menber. Wedge a 2"x4" and pry the engine to the side they will go in with lot of cursing and bleeding.
SLP headers sucked ass now i run Pacesetters life is much nicer
red6speedss
11-07-2005, 08:14 PM
wow the slp headers sound like a biatch. I am glad that I went with pacesetter.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
