After Drill Mod, Does Anyone Have Problem Keeping Pedal Pressure?
Old 11-07-2005, 11:20 AM
KDOG's Avatar
Default After Drill Mod, Does Anyone Have Problem Keeping Pedal Pressure?
I recently did a complete clutch overhaul. z06 clutch, new master , slave and drill mod. my problem is most of the time i have a very sloppy clutch. when the car sits overnight the pedal engages/disengages almost on the floor. after driving it for several miles the pedal firms up. then will occasionally while driving fluctuate between sloppy and firm. i have bled this thing until im blue in the face. i have used the mityvac and gravity feed bled it. Im thinking the amster cyl. is defective. I can get it warrantied but i do not want to replace it. that was by far the hardest part to replace.
said all that to ask this. would the drill mod cause the clutch to lose pedal pressure after sitting?
Thanks.
p.s. im all for a manual/cable linkage. if someone builds it ill buy it!
Old 11-07-2005, 04:22 PM
bad6as's Avatar
maby when you drilled it out you left some stuf in the line. i dont think bleedin it or using teh mitie vac would get it out
