digital window switch
Old 11-07-2005, 08:10 PM
00formLs1's Avatar
Default digital window switch
is there any difference wiring the msd digital window switch than the pill version?
Old 11-08-2005, 09:08 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
go to www.dynotunenitrous.com for the best two stage window switch with first gear lockout.
$119
the pills are bad, relay outputs on the nos brand switch do not work well. the msd box is ok, much less features than the dynotune model.
Old 11-08-2005, 09:23 AM
860 Performance's Avatar
The wiring is the same with both MSD window switches.
Old 11-08-2005, 09:27 AM
Nitro Dave's Nitrous Outlet's Avatar
Im assuming you hasd the old style and it went bad so you are going to the new style. If so yes the wiring is the same.We keep the MSD digital and the new TRick window switch instock.Let me know if I can help in any way.
Thanks
Dave
Old 11-09-2005, 01:35 PM
00formLs1's Avatar
Thanks
Dave
Thanks, i have the msd digital switch from you in sept but have been to busy to even try to install it.i was looking over some of the schimatics and could not find any that were with a digital switch.
Old 11-09-2005, 01:55 PM
Ill check and see if I have a schamatic for you.
Dave
