Now a ticking
Old 11-07-2005, 09:45 PM
02WS6Bird's Avatar
Default Now a ticking
ok so i accidently downshifted from 3-2 @ WOT and now the cars ticking, NO SES light, sounds like its coming from the heads, passenger side near the back... it ticks like a cam would lope. Does this sound like a bent pushrod to you or what else coudl it be? Loose Rocker arm? need to know ASAP
Thanks fellas.
Oh this happened in the Camaro 6-speed it ticks @ idle, in revs, and can be heard only in 1-4th gear while driving Inside the car, unsure of outside for 5-6 but its silent then
Old 11-07-2005, 10:13 PM
RPO_Z06's Avatar
Push rod... !00%
Old 11-07-2005, 10:16 PM
SUX2BU's Avatar
yeah its a pushrod.
Old 11-08-2005, 06:25 AM
02WS6Bird's Avatar
anyone else? just to see if everyone has the same thoughts
Old 11-08-2005, 06:34 AM
Q8CamaRo's Avatar
it should be a bent pushrod i recommened a comp cams pushrods or any aftermarket hardened pushrods
Old 11-09-2005, 03:06 PM
02WS6Bird's Avatar
Do the stock LS1's have pushrod guide plates? I've seen some without and some with if not are they worth gettting?
