Fitting larger injectors, what table to change?
Old 11-09-2005, 11:12 AM
RedWS6 00's Avatar
Default Fitting larger injectors, what table to change?
Using HP tuners and going to fit 42lb/hr Racetronix injectors, what table do I need to modify, its it only the injector flow rate table?
Is it only the 'Injector Scaling Calculations' I need to do from https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html ??
Old 11-09-2005, 04:11 PM
RedWS6 00's Avatar
Of course I will be doing an SD tune right after, but just need to get it almost right before the tune, from what i can see its only the Injector Flow Rate vs KPA VAC table to change for uprating the injectors, but it seems to simple... ...
Old 11-09-2005, 04:28 PM
Billiumss's Avatar
"Flow Rate vs KPA" Table is what you need to change for bigger injectors
Old 11-10-2005, 08:04 AM
RedWS6 00's Avatar
Superb, that seems to work, just finished the install of the injectors, changed that table. Car starts and is very driveable. Hammered the loud pedal a couple of times, when i quickly come off the gas to change gear, a nice pop comes from the rear, fuel igniting in the exhaust. I'll do an SD tune. All looking good so far.
Only changed the "Flow Rate vs KPA".
Quick Reply: Fitting larger injectors, what table to change?
