How DO YOU KNOW WHEN YOUR TRANSMISSION IS GOING?
Old 11-09-2005, 08:04 PM
nikeair042's Avatar
Default How DO YOU KNOW WHEN YOUR TRANSMISSION IS GOING?
I was wondering what some of the sounds/mechanics a transmission would make before it is going out. I dont know if I need a new clutch or a new transmission. I can put it in every gear fine. But whenever the clutch is pushed to the floor, it makes all kinds of noises. Im not sure what the signs of a bad transmission are. Any help greatly appreciated. Thanks
Old 11-09-2005, 08:54 PM
Platinum WS6's Avatar
that noise you hear might be the throwout bearings. Thats a pretty common sound with most t-56's i've ever heard. All of mine have done the same.
Old 11-13-2005, 11:45 AM
nikeair042's Avatar
if it's thr throwout bearings, how hard is it to replace? do i need a new clutch? new transmission?
Old 11-14-2005, 09:56 PM
DarkhorSe_SS's Avatar
Yup, mine is doing the same thing also. I got a 2000 SS. It starts fine and everything but when it gets hot I guess lil by lil the little rattle noise starts chirping and won't go away. It makes that noise after I step on it a few times. I took it to the shop and they told me it's my thr out bearings and wanted to charge me around $200. I bought warranty through my bank but haven't took it to get fixed. Don't know what type of clutch to put in since my gears get stuck once in a while. Is the thr out bearing external or internal. Not an expert on engines.
Old 11-14-2005, 10:43 PM
TheDogofWar's Avatar
the TO bearings are internal, I'd try to replace the clutch while you're in their on both of those cars. Otherwise you're doing the same work again shortly or paying for it again. My 98 has gone 125k on the stock clutch and I seem to be lucky. It's apart for the install at this very moment.
Do some stop and go driving to warm the clutch up and cruise about 65-70 in 6th, then mash the pedal and if the rpms go up momentary and then fall back again, the clutch is slipping. However this doesn't necessarily mean that it's far from failure if it doesn't slip. If it does slip, you've prob got about 2000K max before it leaves you stranded.
..oh and you should also replace your slave cylinder while you're in their too. You need the upgraded 01+ slave, it's the only one GM sells now.
Old 11-15-2005, 09:15 AM
nikeair042's Avatar
Yea, ive done that at 65-70 and no slipping. Just after a hard launch a really nasty smell that hangs around for like 10 min. Then there are the noises galore when the clutch is pressed in.
Old 11-15-2005, 12:18 PM
SporkLover's Avatar
TO bearing. Get that taken care of now you know what it is. It's a $15 part, and it's a shame it takes so much time to change it out.
You can get a heck of a deal on the complete z06 clutch setup + hydraulics from SDPC if you do not plan to do any big power mods. Comes with Fly wheel, Pressure plate, Clutch, and of course TO bearings
Old 11-15-2005, 12:56 PM
What is that website to price the z06 clutch? I need to take care of my clutch and of course the trw out bearings already. Any help
Old 11-16-2005, 03:17 PM
nikeair042's Avatar
In order to put the throwout bearing in, do u still need to take the whole transmission out? Or is it something that is resonably easy? Where can I buy just TO bearings?
Old 11-16-2005, 03:51 PM
SUTTERERMAN85's Avatar
tranny comes out for the throwout bearing. you know its time for a rebuild when gears gring or gears dont work.
Old 11-16-2005, 09:17 PM
quiksilver9531's Avatar
Where did you get a TO bearing for 15 dollars? lol my shop cost through GM with a discount was like 60-70 I dont remember the exact cost but somewhere in that neighborhood
Old 11-16-2005, 09:18 PM
oh and replace the pilot bearing, thats a 8 dollar bearing, and thats what went bad on my trans, almost made me have to replace my input shaft but luckily one of the techs at work was able to clean it up and make it work.
Old 11-17-2005, 12:34 AM
nikeair042's Avatar
where can u by the pilot bearing, the TO bearing, all that good stuff...
Old 11-17-2005, 04:09 PM
Strokinit383's Avatar
Yeah TO bearing definitely isnt 15 bucks. Mine was around 75 bucks at cost from the dealership.
Old 11-17-2005, 04:53 PM
ls1 joe's Avatar
I have the pilot bearings for $15.00 and the throwout for $69 with free shipping and in stock.
Joe
Quick Reply: How DO YOU KNOW WHEN YOUR TRANSMISSION IS GOING?
