dart vs. patriot vs. edelbrock
Old 11-09-2005, 10:59 PM
SSRZ28's Avatar
Default dart vs. patriot
both heads are pretty cheap. which one is more bang for the buck? gonna run it with a f13 maybe?
Old 11-10-2005, 08:00 AM
Gunnar@Patriot's Avatar
Our heads work great with the F13 cam. Our LS6 style 2.02"/1.57"/59cc would be a great head for this set up. It will give you 11-1 compression while remaining at OEM deck height. Each one one of our heads are custom done for your application and are fitted with REV stainless valves, ti retainers, Super 7 locks, custom honed bronze guides, machined spring bases and viton rubber seals. All of this for only $1,195.00 per pair assembled. If you have any questions, PM or give us a call.
Old 11-10-2005, 11:50 AM
PortPros1's Avatar
Originally Posted by SSRZ28
all 3 heads are pretty cheap. which one is more bang for the buck? gonna run it with a f13 maybe?
Give us a shot www.PortPros.com, we are not the cheapest for sure but we are the best. I think the word custom gets over used in this industry but it's truly what we do.
I don't have 100 set's of heads setting on a shelf ready to ship. We build and port our heads one set at a time to order using only the best componets from Ferrea and Comp Cams.
Send me all the modifications you've done to your car and we will build a set of heads just for your application. We have several different valve jobs and porting modifications to match your car.
We can go with a set of LS1 241 castings, we pick these heads up 75 cfm with a 2.020 valve or you can step up to a set of LS6 heads. These heads will flow in the 330 cfm range. Once you send me all your information I can make a good recommendation for you.
Thanks, Harold
PortPros@sbcglobal.net
Old 11-10-2005, 05:33 PM
lock down's Avatar
the edelbrock heads are not cheap they are around $2300 at least I don't consider that to be cheap
Old 11-10-2005, 06:42 PM
SSRZ28's Avatar
no they are not. they are 639 each for CNC heads assembled
Old 11-11-2005, 08:02 AM
Summit shows the bare as cast heads for $617.69 each and the assembled CNC heads for $1,124.69 each. Might want to double check your source before you commit.
Old 11-11-2005, 08:19 AM
JayLS1-327's Avatar
SDPC has them for $1,149.95 each complete and CNC proted.
http://www.sdpc2000.com/catalog/4290...nder-Heads.htm
Old 11-11-2005, 09:22 AM
SSRZ28's Avatar
thats where i got the price from
Old 11-11-2005, 02:08 PM
slt200mph's Avatar
the heads that summit has for $639 a piece are the Dart heads
Old 11-11-2005, 02:19 PM
JZ'sTA's Avatar
THAT PRICE IS PER EACH. Not a set.
That is 1 head only.
Item Qty Price
Complete Edelbrock LS1 CNC Ported Cylinder Heads
Part Number: E61969
$1,149.95 each
$2,299.90
Click here to update the cart quantity
You have 1 additional item in your cart [ View cart ]
Continue Shopping
Old 11-11-2005, 02:20 PM
JZ'sTA's Avatar
Guess that narrows down your choices a bit.
Old 11-11-2005, 02:34 PM
SSRZ28's Avatar
i am sorry you are right. so its between the darts and pp.
Old 11-11-2005, 03:28 PM
INVISIBLEZ's Avatar
Darts.....
Old 11-11-2005, 08:21 PM
67Ranger's Avatar
I have a set of patriots sittin in my room right now, and they seem like they are very good quality heads, from what i can tell. Their customer support was great throught the whole thing. I'll let you know more when i get the motor done.
Old 11-12-2005, 11:31 AM
cowboysfan's Avatar
I vote PP.
fuerzaws6
Old 11-12-2005, 12:54 PM
SSRZ28's Avatar
can i get some pics of these PP heads?
SSRZ28's Avatar
and i am guessing the PP problems of the past are solved?
