LS6 cam specs? Good for forced induction?
I've been doing some research on LS6/ZO6 cams and it looks like this might be the way to go for me. I'm looking for something with a good idle and good valvetrain wear but something that will be more efficient with 8-9lbs of boost then my stock LS1 cam. Would be using 918 springs with this cam if I go with this correct? Also I read that there are different cams for different years, if soo which one or ones work the best for induction and what are the specs? I'm looking for a 2002 - 2003 cam I beleive. Thanks in advance for any info!
Bob
Bob
On a similar note....
Who has the highest recorded power with either camshaft ?
Either Z06, or GT2-3 ? preferebly in a supercharged install....as its easier to turn the boost up with turbos to get power.
