Tint
Tint
What do you guys use at the top of the rear window where all the little dots from the rear defroster cause the tint to bubble up? I was planning on cutting that part out and painting but I would like to know which paint looks the best? The tint is 5%. TIA
My tint guy used black vinyl on that part, then 5% on the rest of the window. You can't see any dots at all from the outside. I've heard of people painting this, but it sounds like it could be a mess, and a pain in the *** as well.
I have mine tinted with no problems. I've used my defroster and it hasn't had any problems. I think if it is installed properly and you don;t use any window cleaner with amonia in it you should be ok.
Local guy here has his dots painted flat black. He showed me up close and unless you know what you're looking for it you can't tell it's been painted. The tint starts below that and is done in one piece. I'm planning on going to the same shop in the spring to have mine done.
