Tuning F13-112 + afr 205s
Hi guys from across the pond
Just received FM13-112 + AFR 205 heads. Money is a bit tight temporarily.
My question is : Is it worth waiting before installing heads + cam til i can afford free flowing exhaust headers ? If i install now and get a good tune will installing headers later require another tune for optimal performance ?
Cheers guys
Rob
Cheers guys
Rob
LS1 Tech Administrator
The F13 has a little too much overlap to work well with stock manifolds. If you can afford to, you run the AFR heads with the stock cam. This way, you can still run the stock tune and not be out the $500. You will pick up at least 30 rwhp and get better fuel economy and better street manners. If you install the heads and cam, you'll need a very comprehensive tune to run well with stock exhaust, and even at that, you be lucky to gain 10 additional rwhp. Your low speed street manners will be crap.
Headers make a pretty significant difference once you exceed 0 degrees of overlap at .050" lift.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Im running stock manifolds with a f13 right now with full bolt ons. I have a "custom" off road y pipe for the stock manifolds and i did 12.8 @ 114 with 342s and stock 10 bolt. The car drives pretty damn good in my opinion. Id like to get heads soon after the 12 bolt. Let me know how your set up turns out.
Kyle
Kyle
