LT1 T56 clutch mechanism
Hi, I am planning to put a T56 behind my Cadillac big block, but I'm wanting to remove the hydraulics and fab up a mechanical system. I have never seen one of the LT1 clutch setups, can someone describe to me how the pull-type system works and how the components are laid out, so I can get an idea of how best to go about doing this? Thanks.
The LT1 is a hydraulic system. The main diff over LS1 is an external VS concentric slave.So the "pull " reference does not mean mechanical. If you really want a mechanical system ( I would not do it) a pre'05 mustang cable set-up would have the most availability with cheap parts( junkyard). I am assuming you have no parts accumulated yet.
It's possible to do that; my T56 is a 1995 box with mechanical in a g-body. But finding a throwout bearing to fit the bearing retainer that's not deep as hell is not happening. Your best bet would be McLeod scattershield & appropriate adapter plate from them, LS1 T56 & proper mech. linkage for the vehicle in which your Cad is installed.
This motor is actually going into an SN95 Mustang. Yes, I know the LT1 is a hydraulic setup. I am planning to convert it to mechanical. I understand the LT1 has an odd "pull type" engagement. I plan to convert it to a standard push clutch.
Sorry I don't have an answer but try www.impalassforum.com. There is alot of information on T56 conversion and this topic has probabilaty been discused. Might have to do a search.
HTH Wayne
HTH Wayne
