boiling water to heat n20
Boiling water to heat n20 is safe right.. as long as i dont let the pressure get way to high?? i only got 3 lbs in the bottle left and wanted to use some of it before the weather goes south...
I've always used hot water, never boiled it. If your really wanna boil it I would keep an eye on the pressure gauge. And you shouldn't have any problem. If you dont have a gauge on your bottle then I would defintly steer clear of boiling water.
